Modern vehicles rely heavily on the use of the drive belt. The drive belt powers the alternator, air condition, power steering, and in some cases, the water pump. Proper operation of the drive belt is important in maintenance of the vehicle.
As the drive belt ages, the stress from powering items such as the power steering pump and the alternator can cause the belt to stretch. When the belt stretches, it can begin to slip, if left unattended.
Not all
types of drive belt systems can be adjusted. Cars equipped with an automatic belt tensioner adjust themselves over time and do not require adjustment.
This article shows you the process to adjust drive belts on a pivot-style belt adjuster.
Warning: Drive belts that are cracked or excessively worn should be replaced. Only belts that are in good working order should be adjusted. To check the condition of your drive belt Signs Your Drive Belt is Worn.
www.rubberbeltmanufacturer.com
