v e l o u o s t a s
http://www.velouostas.lt/forumas/
Mongoose tyax Sport
http://www.velouostas.lt/forumas/viewtopic.php?f=13&t=187
Puslapis 1 iš 2
Autorius:  Mindex [ 2010 Rgp 09 19:07 ]
Pranešimo tema:  Mongoose tyax Sport
Dar vienas mano dviratis:
Frame: Mongoose 6061 formed aluminum, Zero Stack head tube and replaceable hanger
Fork: Suntour XCT MLO 100mm travel, mechanical lock out, preload adjust
Crankset / Chainwheel: FSA A-Drive alloy (22/32/42T)
Bottom Bracket: FSA sealed cartridge
Front Derailleur: Suntour XCM202
Rear Derailleur: SRAM SX4
Shifters: SRAM X4 triggers 24 speed
Cog set: Shimano HG30 11-32T, 8-speed cassette
Rims: Weinmann ZAC 19 double wall
Front Hub: Formula Disc Alloy QR 32H
Rear Hub: Formula Disc Alloy QR and freehub 32H
Spokes: 14G stainless
Tires: 26x2.1 Kenda Komodo black skinwall
Front Brake: Tektro Novela mechanical Disc w/ 160 mm rotors
Rear Brake: Tektro Novela mechanical Disc w/ 160 mm rotors
Brake Levers: ProMax Alloy w/ adjuster
Handlebar: Mongoose alloy riser 31.8x30x635 mm (XS, S) 685 mm (M, L, XL)
Stem: Mongoose alloy 31.8 x 90 mm (S & M) 110 mm (L, XL)
Headset: 1 1/8" Zero Stack
Grips: Mongoose Dual density Kraton
Saddle: Mongoose XC Elite
Seat Post: Mongoose alloy w/ micro adjust clamp
DSCF6574.jpg [ 453.07 KiB | Peržiūrėta 23065 kartus(ų) ]
DSCF6577.jpg [ 454.46 KiB | Peržiūrėta 23065 kartus(ų) ]
DSCF6575.jpg [ 538.05 KiB | Peržiūrėta 23065 kartus(ų) ]
Autorius:  zygfrid [ 2010 Rgp 10 03:32 ]
Pranešimo tema:  Re: Mongoose tyax Sport
Kazin kuo Sram 4, kuris yra Altus lygio geriau uz Deore? Nebent savo smagiais shifteriais.
Autorius:  Mindex [ 2010 Rgp 10 10:16 ]
Pakeite atsiradus kazkokiam garsui. :D Buvo juodi. Pasiilgau senu...
Didelis klausimas :D Ar galima stabdziu diskus tepti automobiliniu stabdziu skysciu? Velomanai.lt parase kad tai blogiausia ka galejau padaryti ir dabar reik mesti sitas kaladeles lauk...
Autorius:  zygfrid [ 2010 Rgp 10 12:43 ]
As vazineju su sram 4. Tik nezinau ar reiktu girti ar keikti. :guscioja:
Istepti stabdziu diskus alyva nera blogiausia ka gali padaryti, blogiau butu reto banginio taukais tepti. Dabar reiktu su kokiu Feiri praplauti :)
Autorius:  Kolobok [ 2010 Rgp 11 22:44 ]
Blogiausia ką gali padaryti, tai apkrauti dviratį tokia "spyna".
Autorius:  zygfrid [ 2010 Rgp 11 23:10 ]
Kiek bandziau, tai tokio tipo spyna su plonesniu troseliu (uz 30 Lt) galima nutraukti per sujungima be pagalbiniu priemoniu (su rankomis) :klaupiasi: . Sitai, tai gal reiktu kokiu sodo zirkliu. Siulyciau pratestuoti kiek laiko reikia iveikti tokia spyna ir parasyti rezultata. O ant dviracio vezioti neverta. Geriau kokias svieseles pritaisyti.
Autorius:  Andriukas dviratukas [ 2010 Rgs 12 00:51 ]
Pranešimo tema:  Pasisioti ant diskų irgi galima
Pilti skysčius ant diskų galima.
Bet reikia žinoti tikslą. Jei tikslo nėra, tai verčiau pasilsėk, ar pavažinėk.
Beje, būna tokie dviračių stabdžiai, kuriuos tepti būtina (ratukiniai būgnai).
Kad reiktų tepti diskinius - negirdėjau.
Jei užpylei ir jie nesprogo, gerai stabdo, reiškia blogiau dar būti gali.
Jei stabdo blogiau, tada bandyk padrožti kaladėlių paviršių kokiu nors šiurkščiu daiktu (dildė, švitrinis popierius). Pašalinsi skysčio permirkytą sluoksnį, ir stabdymas pagerės.
Blogiausias dalykas: leisti apsisioti kaladėles anai žiūrkei, kuri bėga link jo rato. Arba duoti jai įkasti. Tai sukels daugiau darbo ar nemigos.
Blogai dar jeigu padangos Kenda suplyš anksčiau negu nusidėvės. Arba nusidėvės greičiau negu per 15000km.
Nesigilinsiu daugiau. Kitaip, dar nuotaiką blogiau sugadinsiu.
Aną forumą reiktų vadinti Grafomanais. Bet ten ir literatūros, ar bent rašybos neišmoksi. Išmoksi pliurpti.
O tai tikrai - blogiausia.
Autorius:  Mindex [ 2013 Bal 11 22:10 ]
Andriukas dviratukas rašė:
Jei dar kada cia beapsilankysi, gal ramiau apie ziurkes? Pats dar asilu paliksi...
Ignoruojant Andriuka beratuka, pamaciau savo tema Google'j ir pagalvojau kad reiketu atnaujinti sita savo tema :roll:
Is pirkimo dienos (2010.05.15) puikiausiai pamenu, kad tai buvo vienintelis dviratis kuri isbandziau. Is pat pradziu buvo ziurimas Sirrus'as, kuris vis del to, net nebuvo pajudintas is savo vietos. Nuvaziavus i sekancia parduotuve tai buvo dviratis, kuris man pats pirmas krito i aki. Joks kitas nebuvo nuzvelgtas ar nukeltas pabandymui.
Siai dienai odometras rodo 5285Km. Pries nepilnas tris savaites buva nuvaziuotas jubiliejinis 5000'asis kilometras :) Tikriausiai daugumai esanciu cia pagalvos mazai visai, bet man ir tiek uzteko patirti geru ispudziu, susipazinti su naujais zmonemis ir atrasti dar daug ko gero.
over5000.jpg [385.51 KiB]
Atsisiųsta 523 kartus(ų)
Dviratis mano manymu atlaike visai neblogai.
  • Pakeista: keletas grandiniu, zvaigzdziu blokas, guoliai, komplektas stabdziu kaladeliu.
  • Pamesta: mirksiukas, vairo antgalis (kamstis).
  • Nupirkta: papildomi du komplektai padangu, spidometro laidas.
  • Padovanota: dalys prozektoriaus laikiklio gamybai (dekui parduotuvei "Umarai"), gertuves laikiliai, kitas mirksiukas, atsvaitai, tasiukas (pakabintas ant vairo).
  • Nepasalinti defektai: luzes "shifteris", sutrukinejes ratlankis, pagal nuotaika veikianti sake (kartais pati uzsirakina)
Dar karta dekui parduotuvei "Umarai", kad pardave si dvirati, patare ivairiais klausimais ir padejo bedoje.
Labai tikiuosi nuvaziuoti siuo dviraciu dar daugiau, be jokiu didesniu problemu, patirti dar daugiau ispudziu, pamatyti kuo daugiau ir susipazinti su daugiau puikiu, minanciu zmoniu. :)
dvirgal.jpg [397.02 KiB]
dviroland.jpg [311.92 KiB]
Ps. Pastebejau kai kurie buna pasikabina koki zaisliuka ant vairo, po sedyne. Mano atveju keistoka situacija susikloste, todel su manimi kartu pradejo vazinetis pagalys rate :D Gal nuo siol niekas "nebekaisios pagaliu i ratus" jei jau vienas yra?
pagalys.jpg [541.79 KiB]
Autorius:  adseo2016 [ 2016 Sau 15 09:32 ]
gclub
Autorius:  Mindex [ 2016 Sau 17 03:54 ]
adseo2016 rašė:
Aišku galima, tik ne ant įkaitusių ir dar reik žiūrėt ką pili, arba žiūrėt kad gerai nusivalytų po to.
Puslapis 1 iš 2 Visos datos yra UTC + 2 valandos [ DST ]
https://www.phpbb.com/
