Paskutinis prisijungimas: Dabar yra 2024 Spa 09 10:03
StandartinėParašytas: 2021 Rgp 21 12:32
Užsiregistravo: 2021 Sau 22 13:32
Pranešimai: 10
Lost Vape Thelema Quest
The Lost Vape THELEMA QUEST 200W Kit, featuring dual 18650 batteries, 5-200W output range, and is paired with the UB Pro Pod Tank. Outfitted with the QUEST 2.0 Chipset, the THELEMA Quest Kit has an wattage output range of 5-200W and offers a temperature control suite for those that prefer a tailored vapor output. Constructed from durable zinc-alloy, the chassis of the THELEMA Quest Mod utilizes PC materials for a transparent battery door for a visually striking look. Paired with the UB Pro Pod Tank, the Lost Vape THELEMA Quest Kit utilizes coils from the UB Pro Coil Series, delivering massive flavor and vapor from your favorite eJuice, holding up to 5ml within the side-filled pod.
Main Features:
1. 26mm Base Diameter
2. 28mm Widest Diameter
3. 5ml Pod Capacity
4. Side Fill System - Silicone Stoppered
5. Lost Vape UB Pro Coil Series
6. 0.15ohm UB Pro P1 Coil
7. 0.3ohm UB Pro P3 Coil
8. Press Fit Coil Installation
9. Dual Slotted Airflow Control Ring
10. Threaded 510 Connection
Lost Vape Thelema
Lost Vape Thelema discards the traditional pod system design. It provides an excellent visual and tactile sense. The device shell is made of Zinc Alloy which is supplemented by leather design. It is powered by 3000mAh built-in battery with 80W max power, which will satisfy your all-day vape demand. Designed with type-c 2A charging port. the charging is proper fast, reversible and powerful. Thelema Kit also comes with a 4ml visual pod that is compatible with all Ultra Boost Series Coils, including RBA. The pod is built with top filling and plug-play coil replacing. Besides, it features dual-channel airflow and adjustable airflow. There are six theme colors for you, you can enjoy the colorful theme and see the crucial data with a 0.96 inch TFT color screen.
Features
1. Proprietary Quest chip
2. 3000mAh built-in battery
3. Compatible with Ultra Boost Series Coils, including RBA
4. Convenient top filling
5. 0.96 inch TFT color screen
6. Dual-channel airflow
7. Adjustable airflow ring on coil
8. Maximum 80W output
9. Type-c 2A fast charging
10. Two options of drip tip available: 510 DL drip tip and 510 MTL drip tip
11. 4ml visual pod
You May also like:
aspire boxx
vapelustion hannya
eclipse rta
curer vaporizer
